So i got the 6 speed in
#46
#47
OK on the GE engine the AIT which is intake air temp sensor is part of the maf sensor .
For example when you go AEM you use the maf wire to run your Map sensor and AIT sensor.
2 wires for the AIT and 3 Wires for the Map sensor.
So which intake temp snsor did you hook up?
Where did you hook it up at ?
Call me when you get a chance...
#49
Raie i sent you a PM let me know how that works.
Check the Timing, Map sensor/ AIT sensor wiring you made alot of of change to that car so you wanna recheck everything and your car should start.
GL
GL
