Can I convert my 98 SC300 to stick?
I was thinking about converting my car to stick so i can learn it lol plus when i drop in the gte motor i can have some fun with it
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Yes you can but like others have said from being OBD2 AND VVT-i the check engine light from your computer looking for the auto trans will be triggered. I said and VVT-i because if you were 96-97 (which is OBD2)you could just use a 5spd ecu from them years and be fine. But there is no 5spd ecu for or vvt-i motors. Closest possibility is the 01-02 is300. There auto ECU is the same, so ive heard, as our VVT-i years. Dont know how close the 5spd for those years would be. No one has tried and i cant get any info on it other than what i just said.
Im pretty sure DR. Tweak could get it to work with the harness if there was any mods to be made, but that would be more money. and i dont know how bad you want it. You could also go full standalone ECU. but thats alot just to 5spd on NA.
Also thats if you live where the check engine would be a problem for inspection. if not slap it in and ride. with the light on of course.
PS: someone please look into the 01-02 is300 5spd ECU possibility with the 98+ VVT-i SC300's. So the 98+ NA-T guys wont have to eventually go with a swap or standalone to have some fun shifting.
But.... if you have the cajones to try it, this would be a good start:
http://cgi.ebay.com/ebaymotors/2-200...spagenameZWDVW
This might help.
https://www.clublexus.com/forums/5067457-post15.html
here is a link to his new username to PM him:
https://www.clublexus.com/forums/mem...-dr-tweak.html
Yeah in my post i said "so ive heard" that the auto ecus were the same. but i guess not. and i figured if so the 5spd ecu might work. didnt say it was for sure. but thanks for clearing that up. i guess standalone would be only option. or like what i said about not having to worry about check engine light depending on where you live. because here it doesnt matter if its on. but i just didnt want that on in my car. would like it to function normally and not have to check it every so often to see if i have other codes.
I also wonder if doing a complete IS ECU swap would allow you to convert to DBW... interesting thought.
Wasn't trying to shoot you down hard man
. I personally would love to see if there was a way to do this without a standalone. I still haven't come across a standalone that matches the reliability of the factory ECU.
I'm slowely starting to research the vvt-i sc4 manual conversion, but so far I dont think anyone's done it.. at least not that I know of.
If you want a clean swap and not have any CEL's your going to have to get an Electrical Engineer involved. Using oscilliscopes, huge referencing to repair/wiring manuals. Using resistors to simulate solenoids, creating microprocessors to act as an automatic transmission. VERY expensive if you hire one. But it can be done.
