SC- 1st Gen (1992-2000)
Alternator heating
Old 07-02-10, 06:01 PM
dvsccn
dvsccn's Avatar
Default Alternator heating
I have a '96 sc 300. The alternator gets very hot, hot enough to scald yuor hand after running for about 5 mins. Is this normal for this car? I'm on my second alternator trying to solve this, but both heat up pretty bad. Thanks
Old 07-02-10, 07:56 PM
good2go
good2go's Avatar
Hmmm...that doesn't sound right to me...and you're saying that two separate alternators have done the exact same thing?!! The overheating sounds like it's overworked trying to keep up with a high current demand. I'd suggest looking at the rest of your electrical system to see what's draining so much current.
Old 07-02-10, 08:38 PM
dvsccn
dvsccn's Avatar
Yes, the first is a 160 amp, which when cool, bench tests at over 100 amps. Under load in the car , it test's at negative amps, and seems to cycle positive intermittently at 20-30 amps. The second is a so called new alternator, 80 amp, it consistently puts out 40 amps. But both heat. Thanks again.
xStayTuned
08-25-16 05:12 PM
2Tone93
09-19-06 04:32 PM
ted920
08-02-06 08:43 AM
Quick Reply: Alternator heating
