SC- 1st Gen (1992-2000)
change odometer?
Old 04-15-12, 06:10 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I would take the information we can help with such as above, and call your local lexus dealer with the part they can help with.
Old 04-15-12, 08:36 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
I'm in the same boat. I'll give my dealership a call this week. If it costs too much, I'll just have to find a new cluster.
Old 04-15-12, 08:57 PM
Maik04
Maik04's Avatar
How much do used clusters cost? one for a -92-94 sc
Old 04-16-12, 06:46 AM
/Aerostar\
/Aerostar\'s Avatar
Default Replacement cluster...increasing mileage on odometer?
Hi I searched for this and could not find the answer. If I were to buy a replacement cluster for my SC300, that has about 10,000 fewer miles than my car does, could I somehow roll forward the mileage on my new odometer?
Thanks
Old 04-16-12, 06:56 AM
Kalogerus
Kalogerus's Avatar
There are ways to modify an odo but they're federally illegal. Just live with it as it is, hey you got yourself 10 000 less miles on the odo
Old 04-16-12, 09:32 AM
horent135
horent135's Avatar
Just don't register ur car at the dmv until your back to your original miles. If they see you have less miles than the previous last register miles, they will flag your car.
Old 04-16-12, 10:45 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
I would say about $100 to $150 for the older clusters.
Old 12-01-12, 05:24 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I tried the same thing with going from a 400 to a 300 cluster. I did this to get me rpm and mph closer since the swap. You are right, you must swap the chip. I ended up using the 400 motherboard in the 300. This kept my current mileage and all needles and functions work on the money. My 400 cluster was from a 92, and the 300 was from a 93. The boards were labeled same part number but the ending letter were different. Was one A and the other B. Hope this clears up some rumors or theories. I did this myself...
Old 12-02-12, 11:14 AM
TaninAuto
Sponsor
TaninAuto's Avatar
We can also program and correct odometers in almost every Lexus 1992-present.
Old 09-10-23, 01:42 PM
Holden808
1st Gear
Holden808's Avatar
Default It works with board switch to working cluster
I can confirm it works, switch your board from current vehicle odometer to new/used working cluster and you’ll have your original odometer numbers
Originally Posted by imDementeD
ok just a little more info if any one cares..
as i thought pcb does contain the info for the odometer..so swapping the boards worked for the odometer..HOWEVER i have a 92 cluster from my car originally and the cluster i purchased was a 95....these boards are noticeably different..i had to use my original clock with this board as well since the 95 has a temp sensor in it etc..anyway
using the board from the 92 resulted in the needle lights NOT working..im not sure why this is because as far as it looks they are the same in that manner..but apparently they are not....so i swapped back out the pcb to the 95 and put the cluster back together the needles work again the odometer is back to the high 211K miles ..
so overall i feel that you can swap the odometer reading by using a lower odometer back panel pcb however make sure its the same as the one you're replacing..
StarkoS14
04-23-18 09:19 AM
Greg5OH
11-13-13 06:30 AM
Rory
IS - 1st Gen (2001-2005)
15
11-09-10 09:49 PM
turbochris
07-08-08 08:55 PM
spctre
SC400 / 300 Classifieds
08-30-05 03:08 PM
Quick Reply: change odometer?
