SC- 1st Gen (1992-2000)
what goes here!!!
Old 07-06-10, 06:04 PM
2jz-sc
2jz-sc's Avatar
Default what goes here!!!
so i just looked at my wastegate and noticed that i was missing a bolt and missing something that goes conected to it as well can some one tell me wheir it goes and their is cardboard as a gasket on the maf will that cause any problems
Old 07-06-10, 06:14 PM
good2go
good2go's Avatar
Looks like the dump tube (that directs the outflow toward the ground) is missing, as well as the bolt. Pretty sloppy stuff
look at this (borrowed) pic for reference:
Old 07-06-10, 06:16 PM
romycha1
romycha1's Avatar
Yeah, just a dump tube... it can vent to atmosphere, or you can plumb it back into your exhaust.
As far as the MAF goes, I would assume so in the long-run.
2jz-sc
2jz-sc's Avatar
thanks i just bought the car today not bad for 5k cash it needs some tlc
Old 07-06-10, 06:19 PM
romycha1
romycha1's Avatar
Hmmm... I dont' know if I would've bought someone elses NA-t project unless I knew them personally..
If you drive it, stay out of boost, until you figure out what's up with that fuel controller.
Old 07-06-10, 07:06 PM
Vincent123
Vincent123's Avatar
Some really sloppy work here man
Old 07-06-10, 07:29 PM
StiCk3
StiCk3's Avatar
lots of wires all over the place....idk....
and cardboard won't hold up for very long. Even so, i don't like that MAF setup all together.
hope it all works out
Old 07-06-10, 08:16 PM
attzor
attzor's Avatar
Shouldn't the oil feed be at a 90 degree angle?
Old 07-06-10, 08:18 PM
Gspec
Gspec's Avatar
My thoughts exactly.....You got your work cut out for you man....hope you get everything sorted.
Old 07-06-10, 08:55 PM
vietunit
vietunit's Avatar
Good luck on sorting everything out, NA-T projects can become a PITA :/
Old 07-06-10, 10:15 PM
BAD954BOI
BAD954BOI's Avatar
nice to see you na-t but.... you got alot of work to do to at least get that engine bay cleaned up and organized you got stuff going every where. also have to figure out whats going on with that fuel management system!
the waste gate is the less of your worries as of right now.
and you should also look into a turbo blanket.
Old 07-06-10, 11:18 PM
turbodremz
turbodremz's Avatar
optimally, yes it should be at the 12 o'clock position, but sometimes it just doesnt work out that well. take my turbo for example, the compressor housing hits the #1 runner on the manifold, and the return line hits the turbo flange, only remedy, is to clock the center and compressor housing to clear. Although I do plan on getting a different manifold soon, its 'ok' for a while.
to the OP, seeing as how everyone already answered your questions, my suggestion would be remove both the turbo/manifold and intake(whole thing) and see what your working with top to bottom. Sort all the wires, and start from scratch. Mount your FIC inside the car, clean the wastegate really good(be careful with the diaphragm), check for leaks, replace worm clamps with t-bolts, and every coupler that says "Spectre" replace with some good 3 or 4 ply couplers.
Old 07-07-10, 05:29 AM
romycha1
romycha1's Avatar
On a positive note... at least you have a turbo kit. Really though, do what turbodremz said. Take the whole kit off, and just do a whole new reinstallation. That way you know what is done, and that it was done correctly.
Old 07-07-10, 06:04 AM
aka paco
aka paco's Avatar
not really a bad pickup for 5k i guess, if you can get it all running good.
That's just a sloppy NA-T installation, with some shoddy looking work..
If you can get it all cleaned up though 5k would probably be a steal if the car is in descent shape.. you don't see many 2nd gen GS's for under 6k still.
Old 07-07-10, 05:36 PM
bryan767
bryan767's Avatar
btw, if your rev'ing the crap out of it, your going to shoot flames out of that flange. take it to a shop and get them to make you a screamer pipe (a screamer pipe is the pipe that goes from the flange on the waste gate and goes down and points straight at the ground, sounds like a jet taking off).
Quick Reply: what goes here!!!
