New here! Bad wreck...New Car help!
Is the car your looking at a black 92 over in dunwoody? if so, the issue is that there is no TPS or a wire for one to be put in, it needs a whole new harness, even after that, who knows what else could be wrong. I helped him work on it a few months ago, we hard wired the pump to an aux. power source, the fuel pump ran but the engine still wouldn't start, thats when I went to check the TPS, and discovered the absence of one.
what do you mean theres no TPS? i was told the harness is plug and play and that there was an issue with just the fuel pump wiring. Ok so how much would a harness be? im really new to this whole 1jz swap thing what do i need for it to run i have the entire 2jz in my car everyhting runs and stil works as it should.
i want my high beams to look like that
SoarerJzz3
Performance & Maintenance
12
03-19-06 04:07 PM
