SC- 1st Gen (1992-2000)
HID's wont ignite?
Old 07-13-10, 11:53 AM
imDementeD
imDementeD's Avatar
Default HID's wont ignite?
just ordered a kit from xenon depot..and im being a little impatient..i wrote him already but id like to see if i can get this figured out faster hehe..
so anyway its the volt digital hid kit...its a simple plug in play..i dont see how you can install it incorrectly honestly but either way i double checked and everything looks right...
however they won't turn on..
the stock bulbs work no problem
i checked voltage from the head light wire itself..it works..
i checked voltage before the ballast good..
then the two wires running from that to the hid itself has nothing?
so did i just get a faulty kit from the start or is there something im missing etc?
any help is always appreciated..ty
Old 07-13-10, 12:00 PM
ashtray
ashtray's Avatar
Did you try reversing the polarity?
Old 07-13-10, 12:28 PM
jadu
live.love.laugh.lexus
jadu's Avatar
^^^ that did it for me
Old 07-13-10, 12:35 PM
imDementeD
imDementeD's Avatar
nope? ...how would i do that? this kit is like ..**** only plugs in one way..so how would i go about doing this?
Old 07-13-10, 12:42 PM
imDementeD
imDementeD's Avatar
ah i figured it out...its .."working" just not all the way imma try reverse the pins in the plug to make it fit correctly..
but as of right now itll "blink" at certain points while im pushin the connector on..going back to finish this up..report back in a few..ty
Old 07-13-10, 12:43 PM
MrBrock
MrBrock's Avatar
had to do that with mine. The little clip on the side of the plug won't be clipped on anything, but it holds. Just pull the plug going into the transformer, turn it around and plug back in.
Old 07-13-10, 12:45 PM
ashtray
ashtray's Avatar
Just what he said.
Old 07-13-10, 01:09 PM
imDementeD
imDementeD's Avatar
yea i did that..and one side works great..the other side will flicker when i first start plugging it in then nothing..so i pulled the pins out of the plug to connect it directly...still a flicker then nothing...the original light bulb plugs in fine and fires right up...
so overall the reverse polarity worked ty..however im having trouble with the driver side coming on all the way... i was thinking about cutting and splicing but i really rather not..i think imma unhook the pass. side and plug it in to see if maybe the hid kit is the issue or if its the plug car side...
Old 07-13-10, 01:20 PM
imDementeD
imDementeD's Avatar
UPDATE...so i tried the driver side kit on the pass side(which works) and it still will just flicker as im plugging it in then nothing..
any ideas?..like said i removed the pins from the connector that goes into the car headlight plug so its a good connection for sure..and still wont kick on just a slight flicker then nothing...
Old 07-13-10, 01:26 PM
sckyle
sckyle's Avatar
make sure your car is on. i just installed a plug n play on my sc and they kept changing sides with them coming on so i cranked up my car and it works perfect
Old 07-13-10, 01:31 PM
imDementeD
imDementeD's Avatar
i tried it with it in the ON position then with the car actually on..either way the pass. side works the driver side does not.
Old 07-13-10, 03:17 PM
imDementeD
imDementeD's Avatar
more news..woohoo..
so i tried the driver bulb with the pass. ballast..it worked
then i tried driver bulb with pass. ballast on driver side..came on for about 30 secs then back off..
one thing i did notice however tho..with the lights in the on position..the high beams come on but are REALLY faint..hard to see now its a little darker i noticed this..
now whats weird about that is..if i disconnect either high beam they both turn off and the driver side low beam as well...however the pass low beam(hid) stays on...
so do i have a ground issue or something somewhere i need to figure out?
thanks for all your help.
Old 07-13-10, 03:31 PM
imDementeD
imDementeD's Avatar
also noticed when i turn on my high beams..my driver side light goes out..
now i remember when i bought the car both lights worked fine and so did the high beams..
now the driver side seems very faint ...so idk wtf i did but need help fixing it thats for sure..
thanks
Old 07-14-10, 07:50 AM
imDementeD
imDementeD's Avatar
no new info???
Old 07-14-10, 08:06 AM
fuel4blood
fuel4blood's Avatar
Hey I just bought a kit as well and I'm having the same exact issue as you. Steve told me to check connections and swap bulbs to see if the problem follows. Im gonna send you a PM.
Quick Reply: HID's wont ignite?
