sc400 for 1600$ ????
Is it normal that a person sells his car at this price i went to see it 2day and all no problem, need some minor repairs but still i wanted to ask about it
Heres the link for the car:
http://montreal.kijiji.ca/c-cars-veh...AdIdZ208760567
I don't know the rules in Quebec (in Toronto here), but you might want to run this through an emissions test to see if it blows clean. If not, that could be a sign of some more serious problems that need to be tended to. Also, if you have a safety certification process- mandatory for sales in Ontario- then that would probably worth it too. In any case, have an experienced, skilled, knowledgeable mechanic put it on a hoist and take a look at it.
I have a '92 myself which I bought last October. It was/is tip-top and has half the miles of yours. But I still needed to replace the rear cross member sub frame in the end, plus its six control arms, along with the main rear lower control arms. And also a couple of fuel lines. They were all severely corroded. Living in Canada with all the salt on the roads in the winter WILL lead to rot and corrosion. You should definitely check for it before you buy.
Shocks don't cost very much ($200?), rotors are probably around the same, you can get lucky for under $100 for the wheel, you might be able to get an alternator for a bit less, a new battery is pretty much standard in price (just make sure it ain't the starter that's bad!!), and the paint job will probably run you around $2000. After all, that kind of paint isn't exactly common. It's the same with my colour (garnet red).
You should also check to see that the A/C is working perfectly. Same with the heater. And the heated seats. And the stereo/radio/CD changer. The antenna looks like a problem, but maybe not. Are either of the headlights foggy or dirty? I see you'll need a new left mirror. Make sure that the mirrors are adjustable, otherwise you'll need a new ECU. Check the tires too and see how much tread is left on them because new tires are a pretty big expense. Don't forget to look for rust, especially on the inside of the doors and on the underside where rust is really prone to spreading. And if any lights are on in your instrument panel, definitely beware. I may have finally gotten over a lousy oxygen sensor problem which I've been dealing with since day one.
There are others who know far, FAR more about this car than I do. Like Goalie Bill . He told me to check my sub frame. Sure enough, it was bad. If you keep this thread alive, then chances are he'll pitch in soon enough.
The bottom line is that if you buy a car- any car- even if it's for a few hundred dollars, you should definitely know what your liability will be BEFOREHAND. You might have $2000 to spend on it now, but what if it needs another $4000 in work? Do you really have that much to spend? Don't leave anything to chance, or surprise. Or you'll be sorry.
You should also check to see that the A/C is working perfectly. Same with the heater. And the heated seats. And the stereo/radio/CD changer. The antenna looks like a problem, but maybe not. Are either of the headlights foggy or dirty? I see you'll need a new left mirror. Make sure that the mirrors are adjustable, otherwise you'll need a new ECU. Check the tires too and see how much tread is left on them because new tires are a pretty big expense. And if any lights are on in your instrument panel, definitely beware. I may have finally gotten over a lousy oxygen sensor problem which I've been dealing with since day one.
There are other who knows far, FAR more about this car than I do. Like Goalie Bill . He told me to check my sub frame. Sure enough, it was bad. If you keep this thread alive, then chances are he'll pitch in soon enough.
A dyno ain't enough. You need a legitimate e-test. You might want to make the drive to Ottawa to have one done. Check for rust/rot/corrosion EVERYWHERE so you know what's a problem today. Because tomorrow that rot can totally junk your car. The key is having a good mechanic who is willing to tell you the truth about the car, and who can work with you through the problems. And knowing where to find parts doesn't hurt either
1JZ Single SC400
Take it to a mechanic and let them check oit out in more detail, if you arent capable of doing it. Then make your decision. I paid 2K for mine with only 133K on it. Thats a decision you will have to make. Are you going to have the time and money to fix anything? Thats the biggie!
