Should I buy a W58 for $250 with 130k miles on it?
http://minneapolis.craigslist.org/ra...833039542.html
Here's the ad with a picture of the transmission at the bottom.
If I get a decent quote on installing the turbos I'd probably shoot for about 100 extra HP.
If your only going for 100hp over stock, the stock auto will hold just fine. I have been running 9psi on stock compression for well over a year now, and have no issues other than traction. I would suggest waiting and getting an R154, cause like most people, "low" boost just isnt enough and you will want more later.
1jz/2jz bellhousing= $340 at driftmotion.com
clutch, flywheel, pressure plate, and other things that require for the 1jz/2jz+r154 swap= $500+
Not as simple and cheap as you thought right?
still need to add some of those parts to the cost of the w58 too, so its not as simple/cheap either way, not to mention you forgot the clutch lines, slave/master cylinders, pedal set..but why spend all that money on a transmission that has been proven to fail and isnt much stronger than the stock auto? especially for only 7-9psi(+100)? pointless right?
Studiogeek
SC400 / 300 Classifieds
02-02-16 11:38 PM
Studiogeek
08-08-15 02:41 AM
TURBO819
Performance & Maintenance
09-11-10 12:23 PM
