SC- 1st Gen (1992-2000)
Goin Deep into the W58
Old 07-18-10 | 08:06 PM
mtnrat's Avatar
mtnrat
Default Goin Deep into the W58
I hate any unnecessary noise from my vehicles and I have a slight bearing whine from the W58 I just put in. Soooo out it came today. Took 1hr 15min. Nothing like familiarity. I got the W58 rebuild kit from drift motion and will start on it tomorrow. Wish me luck. I also had a very slight shudder that happens when at 2000+ rpm with the engine in all gears and when stopped in neutral or with the clutch pushed in. I think it could be one of 3 things:
1. I put the spacer that was behind the flex plate behind the flywheel. I will remove this.
2. Transmission Mount: I will replace this.
3. Flywheel/clutch plate/ pressure plate out of balance. I doubt this, but will get it checked anyway.
Old 07-18-10 | 09:23 PM
romycha1's Avatar
romycha1
take lots of pics
Old 07-18-10 | 09:48 PM
mtnrat's Avatar
mtnrat
Step by step. This is my first tranny so I might need all the photos I can get.
Old 07-18-10 | 10:29 PM
acsc300's Avatar
acsc300
good luck with the rebuild and you might take a look at your universal joints. they could be causing the vibration.
Old 07-18-10 | 10:39 PM
ishootstuf's Avatar
ishootstuf
+1 on u-joints
Old 07-19-10 | 06:54 AM
mtnrat's Avatar
mtnrat
I would look at the U-joints, but I get the exact same vibration while stopped.
Old 07-19-10 | 07:53 AM
ishootstuf's Avatar
ishootstuf
Well then... I retract my previous post!
Old 07-19-10 | 09:06 AM
mtnrat's Avatar
mtnrat
retraction accepted lol.
Old 07-19-10 | 09:11 AM
Klaus's Avatar
Klaus
Couldn't that vibration also be your center support bearing?
Old 07-19-10 | 09:52 AM
RedPhoenix's Avatar
RedPhoenix
Let me know if you need anything.
Old 07-19-10 | 10:49 AM
acsc300's Avatar
acsc300
haha yea i take mine back too. deff sounds like something in the flywheel/clutch area or a mount like you said
Old 07-19-10 | 12:46 PM
mtnrat's Avatar
mtnrat
I found a couple of things. First, I did not take out the spacer that was previously behind the flex plate. It makes about a 3/16" difference in spacing. Basically enough so that when started in neutral the car would move forward a very very slight amount, indicating that the spacer was allowing the clutch to ever so slightly engage.
Second and more important the wire C clip on the howe bearing had come off and was hung up in the pressure plate fingers. No damage to the fingers at all, but possibly interfering enough so that not all of the fingers were sprung evenly. I think this uneven springing could have caused the vibration. Speaking with my mechanic friend who has installed hydraulic clutches in Cobra replicas cars figures the c clip does very little. So I am going to leave it out. It was doing nothing anyway, just getting in the way.
I really do not think that the clutch/flywheel/pressure plate is out of balance. The flywheel came balanced.
I am going to rebuild the tranny and reinstall and see if the problem was the c clip and or the spacer.
CatManD3W
27
04-18-15 02:05 PM
warreng
SC400 / 300 Classifieds
01-14-14 10:06 PM
Tabaka
Performance & Maintenance
31
09-16-13 06:01 AM
Vwpride12
08-07-13 07:49 AM
TRDmike
25
01-29-11 10:25 PM
