Mk3 or SC300?
Had 2 mk3s, 1 n/a the other 1 was a turbo, loved them both, they are still heavy pigs though. As far as swapping for 1j or 2j engines you will need to move firewall a couple of inches back, to fit the engine, it will be a pain in the butt to do the swap compared to sc, and will involve more $$ than you think or plan. I would use z30 chassis platform for drifting rather than ma70
Good luck
Jmo
Good luck
Jmo
the only "massaging" that needs to be done with a jz swap is for 1jz/2jz with stock twins on a mk3, the twins hit the firewall and it needs some massaging.. but yeah, as far as the motor and tranny go.. perfect fit.
I don't need to search anything. I've done the swap, my friends have done the swap.
I'm not getting offended, im just saying buying new motor mounts is way easier than moving the firewall.. Which no one does. You can buy the mounts here ~ http://www.bicperformance.com/products.htm
i'd probably just stick with the stock 7m then, figure it'd be something i can beat on with a minimal amount of power. i'll worry about more power if/when i become good enough that i need it. thanks for the help everyone
And besides it's a moot point. You DO NOT need a ton of power to drift- just enough to get the wheels spinning and good response. A stock 7m-gte is fine for this, and a BPUed gte is probably the max you really need. Just gut the crap out of the interior and lighten the car up as much as possible. It will make it a really fun car and at the end of the day that's what the whole sport of drifting is about
Lol no need to search when I've witnessed and participated in
