anyone heard of the cxracing turbo kit?
i just looked and if ur talkin about the ~$900 kit for the sc300..ur missing a LOT of stuff to actually turbo your car..
take a look at clubna-t.com..xs power sells a complete kit for around 1800....you will probably still need misc. stuff but its far more complete then that "kit"
It's the exact same parts sold on ebay and through XS power. I just need to be totally honest with you on your budget- I won't ask you what it is but if it's lower than $5k in parts you will not be able to afford what you need. I don't mean $5k for some screaming kit, I mean a basic reliable good running turbo system and all of the associated parts. There's a lot to it. Start doing a lot of research man, and clubna-t is a great site for information on turbo the NA supra and SC. Good luck sir
Do not do it. If you are on that tight of a budget it would be best to withhold forced induction. Piping can be cheaply bought, and if you are running low boost then intercooler, couplers and clamps don't have to be top tier. Turbos, wastegates, manifolds, bypass valves...and basically everything significant should not be skimped on, though. You will end up with plenty more problems in the end if you do not get proven products.
NYCsc300 (10-12-21)
If you do go with that set up, dont plan to run much boost on their turbo. Most guys dont see over 6 or 7psi. Turbo will crap out rather quickly if you're looking for ~15psi.
