do 20's rub with 4people in car?
well...that is a technical question and somewhat vague.
Four large adults will make any car rub if they are obese.
20's will rub if the wrong offset.
Makes a huge difference if the car is lowered and how far it was dropped. (I guess it would be lowered if someone put 20's on it or it would look like a Hummer)
So, based on a 255/30 tire, correctly offset, and lowered 1" with eibach springs, filled with 4 reasonable 150-225lbs adults, no problem.
Hope that helps.
Hope that helps.
If the 20" combo has the same overall diameter (255.30.20 does) as the original specs then it will behave the same as a car with 16" wheels with the original specs. If you have an inch drop, well thats more of a disadvantage (1 inch less to work with).
For example, on my OEM wheels (essentially same overall diameter as my current setup) I had 3 friends in the car. In the back seats I had 1-270 lb friend and 1-220 lb friends (yeah, we were packed in tight
) And the car did not rub unless I hit a bump or a dip a little too fast. If I had an inch drop then I would have had to be really careful.
I've had six people in my SC without the back end dipped down into the well, so four people with a one-inch drop shouldn't be a problem (buying some stiffer shocks will help too). I weigh about 130, and the other five were girls from 100-130 each. That's about a 700 pound load.
ridedumped
13
09-06-05 10:19 PM
