which spark plug wire is best????
Got 3 brands of spark plug wire manufactures:
1. Borg warren(pep boys)
2. bosch(auto zone)
3. Belden(Napa auto parts)
All of them come with lifetime warranty, but I'm looking for the best brand recommended for sc400
also, what should the resistance reading be when its time to change the plug wires? A range of ohm readings is preferred.
thanks,
007
2. bosch(auto zone)
thanks,
007
Spark plug, caps, rotors, pcv, all from dealer, was told wires are on order, but wont be in for a week car need to know if bosch will work a) either put the old ones back on ( they are in bad shape) b)replace with bosch and put oem on at later date. Some feed back would be appreciated. 93 sc400 137k about 6 to 700 miles per week commute.
Not to be too much of a hard ***, but that sounds like fraud to me. You return parts that you haven't used or are defective. You don't use them while it's convenient and then ask someone else (the parts jobber) to pay for your convenience. No wonder we pay so much for parts!
Originally posted by SC300T
Answer: none of the above.
The Lexus wires are the best.
People with 900rwhp Supras run Toyota wires.
You'd be nuts to change them.
Yes but Supras don't have high voltage running through their spark plug wires. Supras have coil on plug, and only relatively low voltage running through the plug wires.
How much does the plug wire set retail for over there? Here it is about 300 USD.
Anyone got a number for carson, my local lexus dealer told me 195.71 and didnt know how long as the message today states. ?What about a part # maybe my local toyota dealer will have them?
Yes, for a daily driven car, the stock will be best, we sell a lot of these as well to CL members, good stuff to make the car run well, especially when they are 100,000+ miles.
As LL said, the Magnecors are good, however they will not fit (not even close!!!) in the stock wire channels or clip brackets, so they will take a fair amount of fitting to get them on the car without pinching them. We had no problems with around 500+hp with those, with MSD 6A ignition boxes and aftermarket coils.
Todd Matsubara
TM Engineering LLC
www.tmengineering.net
Todd Matsubara
TM Engineering LLC
