SC- 1st Gen (1992-2000)
20's or 18's dropped.What looks nicer
Old 07-07-02, 12:04 AM
mjames08
mjames08's Avatar
Originally posted by Lex Luthor
And how much do those dubs weigh......
almost more than my girlfriend
Old 07-07-02, 08:20 PM
Manaray
Manaray's Avatar
Hehehe..I think he was kidding...no one in their right mind would do spinning wheels...I think the new Davins are much cheaper now...HRE no longer makes their wheels (thank GOD!)...dunno who makes them now...
Davin Owners = Ricer with some money.
Old 03-07-07, 10:38 PM
ryanSC300lover
ryanSC300lover's Avatar
20x9 +30 with 255/35/20 and the rear is 20x10.5 +29 with 285/30/20. What do you think?
Old 03-07-07, 10:43 PM
$C300
$C300's Avatar
18's with a 2in drop
Old 03-07-07, 11:01 PM
ACleanSC4
ACleanSC4's Avatar
OMG, I can't believe you bumped this ancient thread...
fender work, fender work...roll and some neg. camber to fit that wide rear tire...
Old 03-07-07, 11:07 PM
G Star
G Star's Avatar
dannnnggg this thread is old...!
but of all threads to bump....why this one??? we have a wheel/tire fitment thread.
Old 03-08-07, 10:48 AM
ryanSC300lover
I had to tony. Mods don't like me starting new threads.
Listen, my other SC is running 275s no problem, you think 285s need rear fender modding?
Also on the front 9 inch, there is 255 rubber, do you think I should go 235s on the front on the 9 inch width 20 inch wheel?
Appreciate the help, prior to dumping like 5K into wheels.
Old 03-08-07, 11:57 AM
Luke_in_SD
Luke_in_SD's Avatar
235's in fine on a 9inch rim. I'm running 225's on a 9inch rim right now on my other car so does not rub.
Old 03-08-07, 01:17 PM
ryanSC300lover
Thanks Luke!
Old 03-08-07, 03:28 PM
hass
hass's Avatar
OMG, I can't believe you bumped this ancient thread......
I didn't notice it was an ancient thread until i read the part where you posted " i have 18s and thinking of dropping it with eibach".
-hass
Old 03-08-07, 03:41 PM
ACleanSC4
ACleanSC4's Avatar
...Listen, my other SC is running 275s no problem, you think 285s need rear fender modding?
Also on the front 9 inch, there is 255 rubber, do you think I should go 235s on the front on the 9 inch width 20 inch wheel?...
It's not the 285 that's the problem, it's the width & offset that will make fitting that 285 a problem.
20x10.5 +45 with 285 no problem...
20x10.5 +29 with 285 rubbing, rolling, neg. camber required...
Use this calculator to determine where a wheel will sit compared to one that's on your car right now...
http://www.1010tires.com/WheelOffsetCalculator.asp
I am running 245 on a 10" rim as well as -2 neg. camber...my rear fitment is 19x10 +25...
My suggestion is, get the wheels you want, make the car fit the wheels
Good luck!
Old 03-08-07, 06:15 PM
ryanSC300lover
Thanks Tony. THe wheels are gorgeous with super DEEP lips. Air Freight from Japan. That is the only reason I am considering them.
2 things wrong with them:
1) They are 20s, and I prefer 19s.
2) Like you are saying, they will require lots of work to make them fit
Old 03-08-07, 06:25 PM
HELLAFLUSH
HELLAFLUSH's Avatar
19's is not one of your options? I would just go for that. But in your case, 18's with a drop.
Old 03-08-07, 06:33 PM
ryanSC300lover
Well HELLA, this setup is only 20s. It wasn't for sale, but after talking to the person, it might be for sale. I like the design and all. I left them a message, asking if they will let it go without tires, so maybe I can fit new tires on it.
Never wanted 20s, so not sure how it will be. WIth stock suspension, probalby look like 4X4, and dropping it, will require lots of fender work and what not.
SIGH.
SISMO817
GS - 1st Gen (1993-1997)
32
02-14-12 12:16 AM
gizbx4
05-01-07 04:49 PM
beauphus
Wheels, Tires & Brakes Forum
02-19-04 01:38 PM
slowmotion
09-23-03 11:58 AM
johnsc400
14
07-10-02 07:38 PM
Quick Reply: 20's or 18's dropped.What looks nicer
