V12 Swap, hopefully...
#77
quad compounded turbochargers would decimate all.
and you can totally boost on 10:1 compression ratio, you just gotta keep the boost low.
I ran 10 psi on the stock 2jz-ge headgasket for like a year with no hiccups and everything was perfect when i took the cylinder head off to finally install the TT gasket. Im lazy what can i say.
There are a few memebers that have been pushing 14psi consistently on high compression.
worst case scenario install meth injection on that bad boy, no need to worry so much about compression till you are tired of whatever 10psi makes on a 1gz.
Anthracite SC
SC- 1st Gen (1992-2000)
04-24-02 03:33 PM
