Oh wow loud in Nuetral. possibly the torque converter going bad?
Yea could be torque converter going bad. Thats where i would start. also check transmount and motor mounts. had all kinds of noises and problems from my tranny but it was just the mounts
Yeah when i get under the car that def where it sounds like, the mounts are all newer replaced them about a year ago. It loud it obviously in the tranny and i is around the bell housing. BTW: I have this thing on a lift guys, i can tell its the tranny, I did replace the rear main seal a couple years ago. So i know the area i'm listening to...
never do a transmission flush...ever. no mater how many times you flush it. youre only flushing debris through the internals
This pan had magnets in the bottom of it, 3 of them so it stays in the pan... Mine had nothing attached to them either. That's what Lexus uses for inspection.
Youre torque converting is going bad. This happened on my 93; the noise started out real low but got louder and louder over the weeks. Stop driving the car because there is no sign when it will go out and leave you stranded like it did me. just get a used low mileage converter
its usually the rear end that whines. My old ae86 did that I put new redline fluid in there and most of the sound went away
You guys crack me up, does everyone really have that much trouble telling between there transmission, there differential, there fuel pump, and there power steering pump? Fortunately I can throw it on the lift so there is no question.
Well I hope not, it was constant every day but after I did that the sound went right away. Wouldnt be a big deal if it went out for me to replace, the tranny was also overfilled from when the rear main was done. It showed now signs of problem till now like a year later though. So dont know if that would have much to do with it...
