Transmission whine, "sounds like supercharger"
#33
ok, if you flushed your trans, post in about 2 weeks with an update. those magnets can in no way catch all debris in the trans moving around. its a good deal to have magnets, and they are on input/output speed sensors as well but they can never catch it all. and it only takes a little debris between plates or sun gear to start a huge issue. lets us know
#34
Perhaps I should reiterate.......what I meant by a transmission flush was to disconnect the hose that runs to the tranny cooler behind your radiator and place it over a bucket. You should measure out 2 quarts of fluid and mark it in your bucket before you start. Then turn on the car and allow 2 quarts of fluid to fill the bucket and turn the car off. Replace 2 quarts of fluid into the tranny. Repeat this process until you have completely clean transmission fluid coming out. Reattach the hose and you are finished. You have already checked the pan magnets so that is not an issue.
Thus, technically this is NOT a power flush and should not spread debris or cause any harm whatsoever.
Again, good luck.
Again, good luck.
#35
Will do
Luxurexus
20
06-17-12 03:40 PM
en11871
27
03-17-08 09:56 PM
