Help 97+ fog lights wont fit in my sc300!!!!!!!!!!
Hi i have a 92 sc300 with a 97+ front end.. I also have 97+ fog lights.. one side the lights fit perfectly..the other side the fog lights dont go in because the AC lines are in the way? Is there a way around this ?
is there any other threads that you know of _ that people having the same problem?....btw i have a 1993 sc300 with the 1998 front end.....im sure there is some other ways to relocate the line....and im guessin its the ac lines but not a 100% sure...the lines are located on the driver side only....btw thanks for you help,,,,
I have that same conversion and both of my fogs are in but it was done by a shop. I will go check first thing in the morning to see what they did and how they did it and let you know.
I don't believe so, but I install and service A/C units for my income in the summer. Basically you can bend the line with zero issues as long as you do not kink the line in any way. The key is taking your time to get a nice smooth bend.
