SC- 1st Gen (1992-2000)
Help on aftermarket head unit install
Old 07-31-10, 03:04 PM
htakhar92
htakhar92's Avatar
Default Help on aftermarket head unit install
i have a kenwood kvt 815dvd deck that i am going to install and i was wondering if anyone knows how to wire the factory speakers to a aftermarket amp..i am having trouble telling which wires are which...
Old 07-31-10, 03:05 PM
htakhar92
htakhar92's Avatar
oh and i have a 1992 sc400 with the stock pioneer system
Old 07-31-10, 03:55 PM
scforlife
scforlife's Avatar
Search for a wiring diagram to find out which wires are which. As for the amp, your head unit already powers your speakers so you wouldnt need the amp to power them.
Old 07-31-10, 04:35 PM
CrZxDrAgOn
CrZxDrAgOn's Avatar
yeah your not going to need to wire the stock speakers to the amp lol, that would prolly blow the stock speakers out.... i have 6 1/2 components in the front and rear, and it still uses the stock wiring , i suggest u get a deck harness so u don't have to cut into the stock harness
Old 07-31-10, 09:02 PM
htakhar92
htakhar92's Avatar
Oh ok...but i still cant find any sorta diagram to find out which wires are which lol...
these are the harnesses i got if some1 could tell me if they work..
Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin
Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker
Old 07-31-10, 09:32 PM
scforlife
scforlife's Avatar
make sure you have the right harness for the right headunit AND the right car. everything you need you can find with the search button on these forums. if you still need help let me know. i just went through this process. and again you will not need an amp unless you are planning to run a woofer.
Old 07-31-10, 10:03 PM
raine
raine's Avatar
https://www.clublexus.com/forums/lex...b-working.html
Check there for the right wires, you can cross reference with what I posted as long as your factory setup was the same.
Old 07-31-10, 10:30 PM
LEXXIUM
LEXXIUM's Avatar
Get yourself a metra wiring kit online kit for about $8, metra dash kit about $30, and a lots if speaker wires to run those to your factory speakers from your head unit.(the metra kit wires for speaker wires are not correct, you will only be using power, ground, remote, and illumination wires from the kit so you don't have to cut any of your factory harness plug) You will also need to locate
your positive wire from your factory plug that goes to your factory amp that's located in your trunk, so you can run amp of your choice. There is a wiring diagram for the radio that's very easy to read search for "amp" you'll be surprised how many posts there are about this, you'll see a big difference I sound quality especially if you replace your factory speakers!
Good luck with your project
Old 07-31-10, 11:35 PM
sc4hunnit
sc4hunnit's Avatar
I have that metra harness with the RCA's, but it sounds like booty when it plays. Why is that?
Old 08-01-10, 09:57 AM
sc300bigtx
sc300bigtx's Avatar
check your ground cause when i hooked up my cd player it sounded junky
Old 08-01-10, 10:22 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Heres another link that I have found. Let us know if you figure it out. You can tap in to the factory wiring in the rear if you want. This is what I did. Good luck.
http://www.lextreme.com/Lexradiowcd.pdf
Old 08-03-10, 05:17 PM
htakhar92
htakhar92's Avatar
Thanks for the help guys...got it done yesterday..will post pics up
Old 08-03-10, 05:20 PM
LEXXIUM
LEXXIUM's Avatar
About time, dude hurry up with pics we want to see pics!
Old 08-08-10, 01:33 PM
htakhar92
htakhar92's Avatar
here are the pics..dont laugh at my steering wheel cover or my hairy legs. ahahahaha
still on the stock pioneer sub..waiting until it messes up then get a new one.
speakers are 4 inch kickers in the door and 4 inch kenwoods on the rear..originally i had bought 6 1/2 kickers for the rear but it was a hassle to get them to fit so just returned them and bought the kenwoods
my brother wired this all up for me...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 08-08-10, 03:10 PM
scforlife
scforlife's Avatar
Nice headunit, but IMO its a PIA to always tilt the screen to use the climate control
Quick Reply: Help on aftermarket head unit install
