Greddy BCC Install Question...
Hey CL, i had a Greddy BCC & SCC laying around in my garage so i decided to wire them into my 1J SC300, i have a soarer m/t motorset, i have done alot of research on which wire goes where...and basically i have it all wired up, except one wire,
On the Greddy BCC there are 4 wires..
-Black wire: Power *Ground* (E1) on the Soarer Pinout
-Red wire: +12v *Power* (+B) on the Soarer Pinout
-Green wire: should go to the map sensor (PM1) on the Soarer Pinout
But i cannot figure out where the white wire goes....i have searched and found the previous threads wit the answers in it, but i jus need to find out where is the TPS wire on the Pinout???
This is one of the Pinouts i used...
http://www.supraforums.com/forum/att...3&d=1150327335
Please Help me out!!!
adjust the voltage to 4.3 - take off the screws on the bcc to get to a inner screw that you will turn to adjust to the right voltage, put your neg leads onto the ground/earth/anything metal on/in the car and the positive leads on the minty green wire on the ecu side.
evileagle
Performance & Maintenance
12-01-09 08:13 PM
