SC- 1st Gen (1992-2000)
brake light on dash keeps showing up, but brake isn't on?
Old 08-02-10, 01:55 PM
Emilio253
Emilio253's Avatar
Default brake light on dash keeps showing up, but brake isn't on?
For about a month now, the e-brake light on the dash keeps coming on and coming off for some reason.. my brakes seem fine, so im wondering what it is.. is this a normal sc problem?
Old 08-02-10, 01:56 PM
kyddo112
kyddo112's Avatar
do you have enough brake fluid?
Old 08-02-10, 01:57 PM
tuterz
tuterz's Avatar
brake fluid is low..
Old 08-02-10, 01:59 PM
Emilio253
Emilio253's Avatar
my brake fluid is not full, but it is not low either.. it's a little below full
Old 08-02-10, 11:32 PM
Photon440
Photon440's Avatar
That's how mine was. I added to the full line and the problem was gone.
Old 08-03-10, 07:20 AM
4evDev
4evDev's Avatar
If you fill it up and it and it gets low again, check the calipers. I had the same problem and a caliper was leaking brake fluid.
Old 08-03-10, 07:26 AM
turbodremz
turbodremz's Avatar
fill your fluid..below full is not full. also like 4ev said, check for leaks anywhere, and be sure that the sensor is plugged in properly on the master cylinder.
Old 08-03-10, 08:38 AM
good2go
good2go's Avatar
Wait . . . the OP said the "e-brake" light was on.
Is there a parking brake indicator on the 400's?
If so, then it's different than the regular brake fluid level light. It would be most likely a mechanical switch on the brake lever, wouldn't it?
Old 08-03-10, 09:28 AM
turbodremz
turbodremz's Avatar
good catch...could be that the e-brake is pulled up very slightly, or the switch needs to be adjusted.
Old 08-04-10, 09:58 AM
Emilio253
Emilio253's Avatar
yeah, where is the switch located at?
Old 08-04-10, 11:15 AM
MrBrock
MrBrock's Avatar
Same warning light is used for both parking brake and low fluid level. Top off brake fluid first and see if it goes out, then move on to the harder stuff.
Old 08-04-10, 12:15 PM
speed6
speed6's Avatar
check a wheel sensor. while drifting, i noticed that the tire blew off and took out a sensor (as the tire wrapped around the spindle)
Cruisin101
01-23-18 01:16 PM
flossabe
09-25-11 02:47 PM
umcne100
RX - 1st Gen (1999-2003)
12-27-09 04:01 PM
jattunit24
Performance & Maintenance
08-27-07 08:15 AM
Din
12-03-02 11:30 PM
Quick Reply: brake light on dash keeps showing up, but brake isn't on?
