NAKAMICI Radio no sound from rear speakers (bass works)
On my recently purchased 1992 SC400 for some reason the rear speakers do not work - the bass center rear works fine but nothing from right/left rears even with fader set all the way to the back - ideas on fix? It is a nice sounding factory radio really don't want to replace...
4" speakers are the stock size but more than likely the speakers you get arent going to be able to use all 4 original mounting holes. the rear speaker covers are held on by 4 screws. you could do the easy way and just rip through the panel because its so thin or you could do the correct way and remove the back seat and some trim pieces to get the rear deck cover out. heres the guide on how to do that
https://www.clublexus.com/forums/lex...tml#post802171
yeah i just ripped the covers off and put some pioneer 4"s in there and sat the cover back in place and you cant tell that i pulled them off. i replaced my front speakers the other day by takin off the door panel. its not that bad. i replaced both door speakers in less than a hour
I guess the first thing to do is remove the speaker and test it before going out and buying new - I am no speaker guy but to just be totally out versus static or something appears odd... My luck it is the stereo unit itself maybe the amp inside
if your front speakers and tweeters work then i doubt its the amp which is actually seperate from the head unit in the sc. i know when i pulled out my stock rear speakers the foam surround on the outside was completely gone
drastic95
06-04-11 01:35 PM
