SC- 1st Gen (1992-2000)
Tape Player Problem - iPod to Cassette Adapter in '92 sc300
Old 08-09-10, 06:08 PM
Koa31
Koa31's Avatar
Hey I had that same problem at one point and what I did was take a flat head screw driver (or a coin) and there's 2 big flat head srews on bottom left and bottom right (Don't srew them out). I know for a fact they are adjusters for something, that enables the tape adapter to transmit sound. Turn them and keep inserting it to Cassette player until you find sound from ur Mp3.
Hopefully it this helps you bro.
Old 09-26-10, 09:31 AM
PEARL2
PEARL2's Avatar
anyone has the issue of cassette not staying in the deck. transmit sound for 2 seconds and spits the tape back you.
Old 09-26-10, 10:15 AM
Exthultu
Exthultu's Avatar
I use a Sony cassette to aux. And it worked fine when I had my stock head unit. I remember paying like 17 dollars for it.
Old 09-26-10, 02:29 PM
Vadim540i
Vadim540i's Avatar
https://www.clublexus.com/forums/sc-...ardwiring.html
Old 09-26-10, 04:50 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Talking
I second going with this route. I bought an aftermarket stereo, but this is a good idea.
Old 09-26-10, 05:16 PM
PEARL2
PEARL2's Avatar
Vandim540i, thanks for the info. Did you do this to your 99, anything different I should know. Also, I'm guessing music from the ipod comes on once the ipod is turned on which interupts the signal between the radio, amp and cd changer.
Old 07-18-16, 01:12 AM
2jzdc
2jzdc's Avatar
Anyone figured out a solution for this?
Old 07-18-16, 10:51 AM
scsexy
scsexy's Avatar
Wire in an Fm modulator that plugs into where the antenna does. The little teeth on all the universal tape to mp3 players are too small and they don't catch.
Old 07-18-16, 11:00 AM
CatManD3W
CatManD3W's Avatar
I was never able to get this to work but there is a writeup on how to make it so you can run off the cd player.....
its under the DIY section......really simple to do and works great.
Old 07-18-16, 11:04 AM
CatManD3W
CatManD3W's Avatar
Here you go....I simplified the process by just using the signal wires from oem head to amp/cd changer
https://www.clublexus.com/forums/lex...em-stereo.html
Old 07-19-16, 11:26 AM
scsexy
scsexy's Avatar
Which wires exactly? you did it without all the relays? Because that seems like more with than my fm modulator plug in was..
mcgray
01-18-14 08:07 AM
ak22801
IS - 1st Gen (2001-2005)
02-01-11 08:54 PM
mkawa6
09-06-08 06:56 PM
cam311420
10-01-07 02:22 AM
wnpalmer
12-18-05 04:30 PM
Quick Reply: Tape Player Problem - iPod to Cassette Adapter in '92 sc300
