SC- 1st Gen (1992-2000)
New Member
Old 07-11-02 | 02:21 PM
soarer 300's Avatar
soarer 300
Originally posted by Ebanks
Cory has never blown up a motor (at least not in his sc300). Cory blew up his transmission, not his motor. Corys motor had 130k on it when he turboed it (on a 7 owner car that didn't seem to have had too great of care) and he never had a motor problem.
-Ethan
Yeah, the only thing that's happened to my motor was the timing belt snapping. It didn't do any damage because neither of the 2JZ series motors are interference motors. I don't know who to blame there. Other than that, my motor has had no problems. Ivan scraped a bunch of carbon off the tops of my pistons as well. The motor probably has a bunch of life left, IMO.
I am the 3rd owner of the car. My mom didn't know how to read a friggin' Carfax report.
Old 07-11-02 | 02:30 PM
soarer 300's Avatar
soarer 300
Originally posted by DIrEctQL
Also, SP pushes for F-MAX, but F-MAX sucks so forget about it. SP turbos are too big unless you're planning on building up the 2JZ-GE motor (notice two SC300s build by SP blew up, they're both on this board).
SP doesn't push for F-MAX. No one pushes for F-MAX, probably not even F-MAX. SP pushes for their own tubular HKS base manifold.
You are WAYYY misinformed about my car. The only problems I've had were the timing belt, and the tranny--making too much power, even for a built transmission.
When you're making as much power as Ethan, hmm, I'd expect some things to go wrong. He's gone through 2 motors:
A. The first motor--fuel solenoid on the dyno went bad. His engine mgmt. nearly saved the day. That motor sounded like a diesel truck anyways...there was a lot of valve tap to begin with.
B. The second engine popped when his tranny misshifted and revved to 10000+ rpms. Maybe partially SP's fault since it was an SP tranny; SP definitely "took care" of Ethan after that and cured the situation.
He's the test rat for the really high HP N/A-t stuff. What do you expect?
I'm not standing up for SP. Just stating the facts.
Old 07-11-02 | 02:54 PM
quikturbo's Avatar
quikturbo
This is exactly the info I've been looking for. Thanks guys! I've seen your car Ethan, at SP as well as 75th. Talk about a sleeper
Guess, I'm going to have to stop by and talk to Larry. Who's car is there with the nice blown hood? Little nitrous backfire.
Old 07-11-02 | 03:27 PM
DIrEctQL's Avatar
DIrEctQL
Chicago Lexus Club Moderator
Yeah, they don't push, but that's what they always say when you ask about turbo kit.
Check. Don't make me send Brian after you.
Old 07-11-02 | 04:09 PM
Lex Luthor's Avatar
Lex Luthor
Cory, what is the transmission situation right now anyways? Did you end up going with a 3000-stall Turbo 350? And as far as Ethan's car, for something that's going to be a single digit car at some point, I think three motors is pretty reasonable considering everything, especially when you consider the bad luck. And Cory, the fact that you turbo'd your whip at well over 100k miles and have had so little problems is damn good proof of reliability of the GE motor and of the turbo kit. As far as the belt, no one seems to believe this is a non-interference motor when we tell them! Ethan, I wanna see some timeslips soon bro......
Old 07-11-02 | 10:23 PM
soarer 300's Avatar
soarer 300
Oh my goodness!!! LOL!!!!
Man, and I try to keep everything on the DL....
Still going with that setup, just a tad bit bigger stall. Stuff is taking so long because I want to do it right the first time. Ya know?
We are very near completion. I will definitely be back to probably market the setup when I am done.
And Cory, the fact that you turbo'd your whip at well over 100k miles and have had so little problems is damn good proof of reliability of the GE motor and of the turbo kit..
Amen.
Old 07-12-02 | 03:22 AM
DIrEctQL's Avatar
DIrEctQL
Amen.
I'm going camping down to your state Cory. How is the chick scene down there?
Old 07-12-02 | 01:58 PM
Ebanks's Avatar
Ebanks
The chick scene depends on where you will be going.... Where are you going?
-Ethan
Old 07-12-02 | 07:48 PM
DIrEctQL's Avatar
DIrEctQL
-Ethan
No idea yet. Just scouting for an idea.
tdubz04
20
10-04-12 08:04 PM
yauser
Performance & Maintenance
07-29-08 10:08 PM
skpark70
07-11-07 05:27 PM
seeya
08-17-05 03:14 PM
