egr is busting my ballz
Canister starts with "C", you need something starting with "V"![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
VSV- Vacuum Switching Valve. It is valve activated by the ECU to control vacuum operated actuator. There are many actuators, many VSV through out the car.
VSV I`m referring to controls opening and closing of the EGR valve. There was also good suggestion from somebody to see if EGR ports in the manifold are not blocked. particularly true for old, high mileage vehicles.
Didnt even catch my own typo..Thanks for the correction
I have block off plates but have no idea to how to reroute the vacuum lines once they are on. I have found a diagram for a turbo lexus but I am just NA. Anyone know how to reroute these lines?
Also I put the resistor in and it didnt clear the CEL. Was throwing an insufficient flow code. Going to get the codes checked again later today or tomorrow.
Any Input is appreciated.
Thanks
Thanks
