NEED HELP ASAP!! Car crank but wont start??
alright so on my way to work this morning it was working fine but later on the day i got off work and start my car the car wont start but it crank any idea?? i looked around and some people said it could be the key, coolent temp. sensor, starter motor or wiring, fuse, fuel pressure, and spark plug any of other suggestion?
wut i would do is check the basics first. number 1 the car cranks so u know your ignition all the way to ur starter is good. number 2 is do u have spark. pull the spark plug wire n remove the spark plug. with plug on the wire check for spark by holding it to part of the engine block. if thats good then u check ur fuel pressure right at the fuel rail by the injectors. there is a schrader valve at the end. do just like the spark test n perform this test while u try to crank the car. if fuel squirts out the lil valve, which looks like a bicycle tube valve, then u got fuel pressure. if everything checked out, which i doubt they did then u got bigger issues such as computer not allowing injectors fire.
i haven't try that yet but i will get to it and the computer not allowing the injectors fire how much would that cost any idea??
