first problem with the sc :/
i was on my way to work and it sounded like my cooling fan was blowing extra hard the higher my rpm's got. so i got out, opened my hood and opened up the throttle and its deffinatly my fan. so now when i drive its sounds like a ups truck. does anyone know what would cause your fan to run high with the rpm's?
no the fan runs normal when the rpm's are low, or when i have the clutch in, but once the rpm's get to 2,500 or 3,000 it starts running really high. i talked to one of my buddies and he thinks its the fan clutch too. it is located by the fan belt?
http://neuralfibre.com/paul/4wd/tuni...ous-fan-clutch
Sounds like the fan clutch as others have said. Try this. With your engine off, try spinning the fan by hand. The fan and metal part in the center should spin while the center section attached to the water pump stays still. There should be some resistance, but enough play so you can spin the fan by hand.
