SC- 1st Gen (1992-2000)
Fenderub's new friend, Garrett!
Old 08-13-10 | 02:09 PM
rwdanthony's Avatar
rwdanthony
Default Fenderub's new friend, Garrett!
mods please close this thread. project had to be determinate. :[
Old 08-13-10 | 02:14 PM
Vincent123's Avatar
Vincent123
oh shieetttt
Old 08-13-10 | 02:58 PM
FutureSC's Avatar
FutureSC
He's a little baby!
Old 08-13-10 | 03:00 PM
TougeSC3's Avatar
TougeSC3
Size and spec's. Why the internal gate? Was it a good deal? Manifold type? Spill it.
Old 08-13-10 | 03:43 PM
turbodremz's Avatar
turbodremz
I would seal up and remove the internal WG, and run an external. If I had to guess, I would say 57mm, .64a/r hot side?....
Old 08-13-10 | 04:33 PM
Sohconthis's Avatar
Sohconthis
Why are you only now telling us since you had the turbo on the 4th? :-o haha jk! Mmmmmmmm can't wait to see boost!!!
Old 08-13-10 | 07:50 PM
SChema's Avatar
SChema
Garrett is always a good friend to have.
Old 08-13-10 | 08:03 PM
rwdanthony's Avatar
rwdanthony
id prefer the wastegate for now, just in terms of low cost and alot less "attractive" i got a pretty good deal on it, its with a AVO cast iron manifold, with a couple of other goodies.
after calculating the inducer/exducer, i hope i calculated correctly to be 54mm trim, .84 A/R hotside [the hotside is stamped .84]. this is my first turbo and first time boosting a car. so im still reading and learing trough many of my friends.
i actually had the turbo for about a month or so now, but i been collecting some parts untill i thought i was ready for install.
Old 08-13-10 | 10:51 PM
rwdanthony's Avatar
rwdanthony
deleted....
Old 08-13-10 | 11:23 PM
MIGS's Avatar
MIGS
nice, since it's bottom mount, you wont have those clearance issues with your intake pipe and the damn distributor right
Old 08-14-10 | 12:15 AM
daSC4's Avatar
daSC4
Mmmm I can already hear it spooling up
Old 08-14-10 | 12:19 AM
thatWESguy's Avatar
thatWESguy
doing work! I likes what I see, can't wait to hear it mang
Old 08-14-10 | 12:24 AM
Sohconthis's Avatar
Sohconthis
Careful with that return line! the tubing can bend easily and backup into the turbo and blow past your seals into the exhaust! silicone tubing like http://turbosunleashed.com/shop/prod...roducts_id=156 will be much more resistant to that bending.
Old 08-14-10 | 01:32 AM
rwdanthony's Avatar
rwdanthony
exactly, only issue i had was the heat shield, but the rest should be fine.
matts 3" should be going on my car, you guys should come down again though later on when my cars running!
thanks for pointing that out, the way my turbo is mounted though doesnt have too much bends for the oil return but ill get silicone just in case
Old 08-14-10 | 01:59 AM
camberSC's Avatar
camberSC
*******....... MORE!!!!!!!!!!!! loil
Quick Reply: Fenderub's new friend, Garrett!
