Better gas mileage with 97-00 ECU?
I was talking to my friend yesterday and he said he was looking for a 97-00 ECU since it's supposed to yield better gas mileage. Is this true? He owns an SC300 and I own an SC400 so I was wondering if a newer ecu for my model would do just that, give me better gas mileage?
switching ecu's won't work because for certain years Lexus changed around the sensors and sensor types.
92-95 ecu's are interchangeable
96-97 ecu's are interchangeable
98-00 ecu's are interchangeable
Switch them around and they wont work unless you plan on doing more work.
Miles per gallon is ALL about how you drive. On my 96 SC400 with ~120k miles I have gotten as low as 9mpg and as high as 27mpg average on the ENTIRE tank.
So different sensors for 96-97 than 92-95 because it is OBD-II that is correct. However, that doesn't mean the ECU won't work. For instance an OBD-II ECU on a 93-95 TT Supra is an upgrade as there is a lean spot in the OBD-I ECU that is remedied by this. It's plug and play, it's just that all your diagnostics and such will be off- but the car will run perfect. This is for the tt supra at least, it's probably worth a try with the 97 ECU.
Check out this thread, it's very helpful.
https://www.clublexus.com/forums/per...fferences.html
Just know the #1 difference is in the maf sensors. In the 92-95 they use a karman vortex maf sensor. It uses 5 Volt pulses to determine the amount of air flow. While in 96-97 maf sensor, it uses a hotwire that determines the air flow from a voltage between 0 and 5 Volts.
@TLDriver, yes one of those piggybacks will work, but after a while the effects become diminished because the ecu starts adapting from those changes.
@Klaus, from what I understood, to get around that lean spot, people did the 12 volt fuel mod.
Well, if you try a 96 or 97 ecu on your older car, the worst that could happen is that it won't start. But like I said, if gas mileage is your concern, you need to first make sure your car is fully tuned up and then change up the way you drive.
The attached file is also a good read for anyone else who is interested.
