will mk4 supra rear cross member and diff on '92 sc3 5spd
my rear cross memeber has some rust on it and rear diff seals are leaking, i wanna buy and swap in thea mk4 supra rear cross member and lsd differential
if you cant get an answer here , go over to SF and ask there. But i know for a fact that the 6spd diff bolts up without the rear cross member but you'll need the axles too. hope that helps
it works if u would have searched, there is no point its the same thing. u gotta swap half the things anyways it sounds like a big waste to me. take urs off and get it powder coated.
The entire rear subframe from a MKIV will bolt up. But it would be pointless. Pull the rear subframe, repair rust, replace bushings, swap in a new seals, and call it a day.
ScottRunot has the whole setup and in on of his build threads he explains and measures that they are different... basically the supra rear handles better.
