MAF Delete & BFI
Hey how do you get rid of the MAF Sensor mines a pain in the *** no matter how much i clean it or anything it keeps messing up. i'm pretty sure theres a way.
and can someone explain what a BFI is and what i do to my stock airbox to make it work. and is it rerally better then the Injen ram air intake
dont expect too many people reply in your thread. you should do a search before posting questions like these. i can remember at least 20 different threads talking about both subjects. use the search function and you'll get your answer. it also doesnt help that you didnt say what car and motor your asking the question about.
Im in a good mood, so this one is free.
BFI= Big Fu***** Intake. Easiest way to put it, cut a big hole in the front of your stock airbox exposing the front face of the filter. Search "BFI" and you will find pics.
As for your MAF, there are several ways. #1 get a JDM (all the JDM's are MAP based) swap, 1JZ or 2JZ. #2 convert over to a GTE (must be a JDM) ecu like I am in the process of doing. Or #3, go to maftpro.com and start reading about the translators.
Bottom line, is you need to search.
thank you veeeery much turbodremz
im sorry bout the BFI deal i kinda did the research after i posted so thats my bad
as for the MAF i honestly couldnt find much other then the MAF translator
but thatnk you again
i mean im by far no electronics wiz but the way id imagine it to be would be you could get the ecu, the MAP sensor, and wiring and put it all together
but then again like i said i am absolutly no electronics wiz
