What would be the best injector upgrade?
Ok heres the deal got a 2jz-ge guna be doing a jdm gte ecu conversion so im guna have to upgrade the stock injectors and fuel pump
im getting a walbro 255lph-HP and now just trying to figure out what would be the best injectors
Candidates:
7mgte 440cc's
TT 550cc's
RX7 550cc's
i understand that to put in the 7m & TT injectors you have to wire in a resistor pack, in my eyes the rx7 550's seem the most logical cause they are just direct replacement plug and plays
if there's something i dont know help me out id appreciate it
Candidates:
7mgte 440cc's
TT 550cc's
RX7 550cc's
Best bet would be to just shop around. I got a set of RC 440cc high imped. injectors (direct drop in, no resistor pack needed) with less than 1k miles on them for $100 shipped with the clips. IMO, NOT dealing with a resistor pack would be ideal, but its not hard to wire one in. Just look around and find the best bang for the buck. There is always someone upgrading, and just needing to get rid of parts. Be sure to check supraforums.com classifieds as well.
Oh and be sure to remember that your fuel rail is for top feed injectors, and the stock TT GTE injectors are side feed. So in that case, the RX 550 would be my choice.
Oh ok my bad we are refering to the same link right?
https://www.clublexus.com/forums/sc4...-for-sale.html
Just curious cause i dont know the difference but what is the difference?
Same ones. The GE injectors are top feed, meaning the fuel rail sits on top of the injectors and is pumped from top to bottom into the engine. Side feed, the injectors are physically inside the rail and are fed fuel from around the center body of the injector.
Im sure there may be a way to modify the GE manifold (lowers) to accept the GTE fuel rail and side feed injectors, but speaking dollars, its more convenient to stick with top feeds
yeah ive been looking round the classifieds here, supraforums.com, and clubna-t. im pretty much sold on the rx7 550s now im really in no rush though so im sure ill find a good set in time it seems people sell em pretty cheap.
thanks for the tip ill check it out
