made a big boo boo w/pics
#31
The most visible locations are the pinch welds that run along each side of the car; I don't like those though, over time they tend to distort. Frame rails that sit further in from the pinch welds will work as well. You can also use the control arms; harder to get to, more suitable for jack stand points. The tow hooks can also be used as lift points.
Thanks for the picture.
#32
I would invest in one of those aluminum race jacks if you plan on adjusting your suspension often. They come in handy, they get the car up in the air quickly. The ones at Sears are about $150.00.
#33
Omg you lucky SOB... I would get Jack Stands ASAP!. Myself even under my car with jackstands I feel a little uneasy. Im glad your okay. I honest now take it to my friends lift to work on.
#34
#35
#36
Does anyone know who makes those super quick jacks? This guy I knew had one that got the car up to a good height with 2 or 3 pumps.
#37
Yes the main thing is that your okay.
Im sure your going to learn alot from this one.
Looks like you got away lucky on the damage---nothing a hammer and a few rivets cant fix.
Good luck
Good luck
#38
#43
my plan of attack and my weapons... silicone, heat gun, and various hammers
after peeling back the carpet it wasnt as bad as i thought it was. but did noticed what looked like sound deaden-er
realized i couldnt hammer through the nasty stuff decided to heat it up and scrape it off
after some rough hammering i got it back flat sealed it up and put the floor mat back.
gonna buy some dynamat later and put some on top
#44
kokonutjc
15
03-15-09 03:15 PM
