SC- 1st Gen (1992-2000)
made a big boo boo w/pics
Old 09-03-10, 08:19 AM
cheez
cheez's Avatar
Default made a big boo boo w/pics
sooooo i went to change my outer tie rod ends cuz they were hideous. so i jacked up the passenger side on which i thought was the frame and removed the wheel. couple seconds later, i hear "doom" and the car drops about 6 inches. turns out that i missed the frame about an inch and i jacked it up on plastic next to it. i then proceeded to jack it up properly and finish my tie rods. after i realized i made a decent sized hole on the bottom of the car and on the passenger side floor theres a hump which doesnt look so bad. so my question to u guys is wut would be the best method to fix this problem?
Shot at 2010-09-03
Shot at 2010-09-03
Shot at 2010-09-03
Shot at 2010-09-03
Old 09-03-10, 08:21 AM
cheez
cheez's Avatar
i just realized my jack, jack stands and car r all red -______-
Old 09-03-10, 08:36 AM
SCLex218
SCLex218's Avatar
lolzzzz ^^^
Old 09-03-10, 08:47 AM
TroySC300
TroySC300's Avatar
Oh dear....
Old 09-03-10, 08:49 AM
nfordhk
nfordhk's Avatar
I don't even know Iv never actually seen it happen to someone
Old 09-03-10, 08:51 AM
stockhatch
stockhatch's Avatar
Looks like you can just pull the carpet, hammer the sheet metal flat again, and weld it back down. Or, you can put some seam sealer or a bead of good quality silicone sealer where the joint laps, and then drill and pop rivet it back down. Make sure to seal the rivets if you go that route. Doesn't look like too big a deal to me.
Old 09-03-10, 08:52 AM
stockhatch
stockhatch's Avatar
Thanks goodness you weren't under there when it dropped
Old 09-03-10, 09:04 AM
cheez
cheez's Avatar
thanks stockhatch that was my original plan hopefully all goes well
Old 09-03-10, 09:16 AM
gorjusguy
gorjusguy's Avatar
ur f'n lucky dude
Old 09-03-10, 09:41 AM
good2go
good2go's Avatar
Originally Posted by cheez
...so i jacked up the passenger side on which i thought was the frame and removed the wheel. couple seconds later, i hear "doom" and the car drops about 6 inches. turns out that i missed the frame about an inch ...
Shot at 2010-09-03
This is just plain frightening.
How do you "miss" by an inch??
DO you even know that you are supposed to lift your car from specific reinforced points along the edge seam and not from the "frame" you were "missing"? Technically, speaking the car has no frame, it's all just sheet metal. That's what uni-body construction is all about.
Bottom line, you got off easy on what could have been a very costly (FATAL) mistake
Old 09-03-10, 09:47 AM
Luxor
Luxor's Avatar
Reminds me of the story when someone here on the SC forum took their car to a mechanic shop and they jacked up the car in the back directly under where the spare tire is causing the center of the spare tire hole to be pushed upwards.
Old 09-03-10, 10:10 AM
Ali SC3
Ali SC3's Avatar
you are lucky you weren't wrenching under there.
Just peel that carpet back (or not) and go at it with a rubber mallet or hammer.
you can set a flat block of wood on top of it and hit that with the hammer so you don't go too far the other direction or make a big gaping hole.
Old 09-03-10, 10:34 AM
ElitistK
ElitistK's Avatar
don't feel bad, because this thread is better than most threads in the 1sc section recently
Old 09-03-10, 10:46 AM
96SC4
96SC4's Avatar
LOL
OP, you're lucky. now go play the lottery...
Old 09-03-10, 10:50 AM
stockhatch
stockhatch's Avatar
What he says is true too. The "frame rails" are just light steel boxing that would probably collapse under the weight of the full car. You can jack the car from the 4 jack points mentioned in the owners manual, as well as at the rear diff, and under the front cross member.
The factory jack points are along the pinch seam that runs right under the doors at the rocker panel. There are notches on either side of their centers to help you locate them.
You can also get away with jacking from certain strategic areas on the subframes and suspension, but I won't specify where since someone may screw it up and drop a car on themselves.
Quick Reply: made a big boo boo w/pics
