oil leak behind plastic covers
i have a major oil leak behind the plastic covers on my 95 sc400. im thinking that its a crankshaft seal. the manual has a long and involved procedure to do this. is there a short cut to do this ,i dont have a lot of time till i have to have it running.
I second this suggestion. It might even be the cam seals that are leaking. The oil is just going all the way down the front of the motor. Take a really good look at your timing belt while you're in there too. Oil on the timing belt is bad.
BMWZ3
04-11-10 07:54 PM
