cost of rebuilding the engine?
It really depends on the condition of your motor. It cost me about 1900 to rebuild mine... $800 for machine work and about 1,100 for parts, and thats with me pulling the motor and doing most of the work myself. We also rebuilt a na 2j at my shop last week, the bill came out to $2,550 parts and labor included... Most shops charge alot more for labor though.......
Exactly, you are getting a used engine with who knows how many miles and who knows what could go when.
Getting an engine rebuilt is pretty much resetting the mileage on the engine to 0.
What we are saying is that a rebuilt engine is better than buying an engine pulled out of a parted car. Its obviously going to be more expensive to get a rebuilt engine but what happens if you buy the USDM 2jz and it goes to **** since it has 150k on it and the oil was only changed 5 times or something?
I think your answer also depends on what your plans are for the car.
Turbo in your future?
If so... mild or wild?
Search. This was on the fourms.
http://www.importperformanceparts.net/
Toyota Supra 2JZGE 24V DOHC 6 cyl. 2997cc 1993-98
Bore Includes: Engine Kit #/Price
2JZGE 86mm Std Complete Gasket Set
Cometic Head Gasket
ROSS/Wiseco Forged Pistons
(86, 86.5, 87mm) and
(8.5-1, 9-1, 10-1, 11-1 comp ratio)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Additional Parts Available:
Connecting Rods (Eagle/Oliver)
Pauter Connecting Rods EKTO36MPX (93-97)
EKTO36LMPX (1998)
$1099
Following Kits w/TOGA HV Oil Pump
EKT036MPXG (93-97)
EKT036LMPXG (1998)
$1259
Cometic Head Gasket
Performance Rings
Thrust Washers
Timing Belt
EKTO36LMPX (1998)
$1099
EKT036MPXG (93-97)
EKT036LMPXG (1998)
$1259
It just depends what you want to do with the car.
Cost can vary greatly depending on how much work would need to be done on it. Decking the block, honing the cylinders, milling the head, cleaning up intake and exhaust ports, etc...while adding parts that need to be replaced can add up fairly quickly.
Used motors should be just as good as rebuilt motors in terms of being built. They were originally built by professionals as well. If you're talking about blue-printing a motor, that's a different story; then again a normal rebuild does not include blue-printing.
