Oil pump problem?
car started running hot and smoke was coming from under the car...not too heavy..but i parked and popped the hood...took off the oil cap....smoke was coming from the oil heavy...i dont know if it was oil pump or what. anyone know how to check if oil pump is bad?
Thanks
oh yea..there was no major knocking so im assuming headers are still good!
Thanks
I'm not following why you are assuming failed oil pump ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Was your cooling system working properly? (ie. coolant level, fanbelt, radiator, thermostat, hoses, etc.)
As was was mentioned above, oil level!!!
Engine tune (ie.timing)
Start with the most likely culprits before you start chasing more obscure failures like an oil pump.
i recently had got an oil change. about 2 weeks ago. it read full. i pull the stick out and the stick itself was steaming! i just had the pulleys re aligned ..new timing belt..water pump..distributor coils..plugs/wires..and new radiator. the cooling system was working fine. it was full of antifreeze.
smoke was coming more from the driver side of the engine...right around the oil area. i took the cap off of the oil and it was steaming yesterday. but i went outside to crank the car today and it started up. kind of hesistated a tad but after all pulleys were engaged it ran fine. it sat about a minute and i started noticing smoke (black) out of the driver side tail pipe a little. not much. so i immediately turned off the car.. idk what it could be
a neighbor next door said that it seemed i had a bad oil pump. thats only reason why i said that. but i didnt hear any ticking or knocking so i doubt the headers are bad.
well i found the problem.
i had recently replaced oem radiator with an aftermarket steel and the lower radiator hose had a hole in it. i had no antifreeze in my car! go figure the oil getting hot etc...
thanks for all the input thow guys. it always feels good to have support!
