JDM ECU Conversion
JDM ECU Conversion
Ok this is guna be my first project thread so here goes
thanks to turbodremz who is doing same thing right now and probably will have his done already, also to Ali SC3 for all the help
check out his thread it help me alot:https://www.clublexus.com/forums/sc-...-odb1-sc3.html
heres the parts i got:
JDM Aristo ECU
Walbro GSS 342 Fuel Pump
JDM TT MAP Sensor
RC 550cc Hi Imp Fuel Injectors
all i need left is a JDM IAT Sensor
should have that soon
ill keep this updated as often as i can
hope you like it
JDM Aristo ECU
JDM TT MAP Sensor
hope you like it
looking good, I don't see a turbo on that list but the TT ecu is still a good upgrade especially if you are going turbo in the future!!
you may be running a bit rich @ WOT with the 550's and the stock map sensor, but nothing an safc can't fix pretty easily. let me know if you need more help.
yeah good idea im guna do it eventually
probably will do it now
unfortunatly this is my only car so its a lil tough doing things that take alot of time
yeah ill be putting in a t67 turbo in the future here soon
i apreciate all the help man i really do
and definatly considering getting the safc
i got time so really no rush to get everything i need
I was going to post up a thread too, but decided to just update the other thread. But it will be nice to see this conversion on one n/a SC and one na-t, but I still have a ways to go.
Keep us posted...also have you decided if your going to use the heated o2's or resistors? If you want the resistors I can send you the link for them.
will do for now im just going to do the conversion and worry about the o2s later
i want to use aristo sensors but if i can not figure it out probably will just go with the resistors so if you wouldnt mind send me the link thatd be great
Here is the link: http://www.mouser.com/ProductDetail/...I4AT3%2flbQ%3d
I should have mine in and wire up pretty soon, so once its up and running Ill let you know how they do.
dubseven
Performance & Maintenance
04-09-15 10:47 AM
