wiring gm/aem map & gm/aem iat sensors
okay, so iv searched and iv found a few different answers. i need a definite answer though.
i have a aem ems v1 in my sc300 with a 1jzgte.. im trying to wire everything up and this is the last bit im stuck on.
MAP SENSOR
GM 3.5 bar sensor:
On the GM MAP sensor you have A-B-C
Pin A= GROUND
Pin B= MAP SIGNAL OUTPUT
Pin C=5V
GM map
![](http://turbomirage.com/miata/afc_install/gm3bar.jpg)
AEM 3.5/5 bar sensor:
CAR HARNESS SENSOR
Blue/Red_________________Red____________5 Volts
Brown/Black*_______________Black__________Ground
Black/Yellow_______________Green__________Output
AEM map
![](http://www.amsperformance.com/cart/images/P/AMS_Performance_AEM_MAP_Sensor_500x375-01.jpg)
however this info is for a mk4 supra, im only assuming itll work for a 1jzgte?
IAT sensor
![](http://i143.photobucket.com/albums/r144/enot767/IATsensorsupra.jpg)
both wires on the iat are the same, since it just reads voltage.
wire 1 > pink/blue
wire 2 > brown/black
gm iat:
![](http://mercracing.net/wp-content/uploads/wpsc/product_images/iatwpiggy.jpg)
aem iat:
![](http://www.snowdigger.com/the_garage/garage_projects/iat_sensor_mod/iat_sensor_kit.jpg)
i believe the map is correct, im just confused on where i wire the IAT to, which wires do i jump
MAP SENSOR
GM 3.5 bar sensor:
Pin A= GROUND
Pin C=5V
GM map
CAR HARNESS SENSOR
AEM map
IAT sensor
wire 1 > pink/blue
gm iat:
aem iat:
preston145
Performance & Maintenance
10-09-12 06:49 PM
