HELP. Gorilla Small Diameter Lug Nuts + OEM 5 Spke wheels???
I ordered this kit from Summitracing before I looked at the OEM lug nuts.
http://www.summitracing.com/parts/GOR-21133HT/
I see that the OEM lug nuts have more of a lip (wider) than these tuner lug nuts. Should I not install these gorilla lug nuts with these OEM wheels and instead by the "standard" lugs instead of "tuner" lugs? I know these tuner lugs would be fine for aftermarket wheels but am worried they are not wide enough for the stock wheels...Any help would be appreciated. Thanks!
Same answer, I would not use Gorilla lugs on stock wheels. I have gorilla lugs for my Works and use my stock lugs with the factory wheels. I've had my gorilla lugs off for a while but if I remember correctly, they cone in slightly and would definitely wobble and probably snap a few lug bolts off.
Thank you for your responses. I am missing 2 lugs and thats the reason why I purchased the set. I will ship the kit back and just go grab 2 from Lexus. Thanks!
bentleymp2
12-26-15 06:44 PM
