Finally doing something about the "silent" lock in the 92-94 SC
Check out the below link youtube video. Found him advertising his services on craigslist in San Francisco.
http://www.youtube.com/watch?v=31SpL...eature=channel
No more silent alarm lock.
That's all good and well but i'm trying to keep the car as OEM styled as possible. Even if I got an aftermarket alarm I would pick up this unit for the clean OEM style lexus sound rather than the annoying chirp that comes on all of the DEI units. Also not having to have a seperate alarm unit and having it integrated into the key? Nice
Style trying to figure out what relay I would use- do our parking lights take 30amps?
The relay is used to bump the output of the amperage up. You said the output is 200ma, well you can use a 5 pin relay. Radio Shack has them, shoot Walmart has them in the car audio section. More specifically, I think it is a SPST 5-pin relay. If you tell me the polarity (positive or negative) of that 200ma output I can tell you exactly how to hook it up. The intructions should say.
Lock/Unlock antenna is rear defogger
Jonas
Can someone tell me what the "beeping" sound is when I turn the ignition off and remove the key (with lights OFF and door CLOSED)? It just started doing this for the first time since I've had the car and I'd like to turn it off! Can't find a logical topic in the Owner's Manual to cover this....
ISFFUN
SC- 1st Gen (1992-2000)
06-28-15 01:22 AM
97JZA80
10-05-09 04:52 AM
rwdanthony
12-08-08 11:28 AM
Jewcano
15
08-18-08 01:13 PM
