Changing Calipers
if the rotors are worn badly, they will develop a lip that the pad won't slide over. you may need to spread the pads, pry them apart. if this is the case, you really need to get new or get your current rotors milled (and new pads, of course).
aside from that, calipers should be easy.
Yeah. I took the two bolts off. Its sliding it off thats a problem. Its this little center piece thats giving me a problem. I can't slide it off for nothing!
I had to unbolt the two bolts from the caliper pins to separate the caliper from the bracket so I can remove the pads. And then unbolt the mounting bracket. My rotors were worn out and had that lip.
If that is your case, then you will need rotors as well.
Sorry guys! I meant rotors. I was extremely tired when I put this post up the other day. Got em off though. @ SH JZZ30, yeah man my rotors were rusted and stuck to the center. We banged them off. This was just the front though. Gotta do the back rotors Saturday. Anybody know what size socket I need for the center bolt on the rear rotors???
Inspect your parking brake pins and springs for any damage too. I recently had to reset mine when the pin/spring mechanism slipped out of place and gave an awesome rattling sound for a day.
Realistically, it should take about 2 hours to change all four rotors and pads. Please only use hand tools when removing and installing the caliper bolts. I don't know how many times I've had to kill myself when mechanics over torqued bolts with air tools or fighting over a stripped bolt.
Take your time and do it right the first time.
drgrant
03-31-19 12:26 PM
cssnms
GX - 1st Gen (2003-2009)
10-11-18 07:44 AM
