SC- 1st Gen (1992-2000)
Toyota specialty tools
Old 09-23-10, 01:43 PM
ClearP
ClearP's Avatar
Default Toyota specialty tools
My friend and I are doing a swap on his car, however, reading the repair manual, there are a number of "special service tools" needed to do some of the tasks!
These tools includes Pulley Holder, Pulley Puller, Valve Spring Remover, SST for pushing in Cam seals and more! My question is, what did you guys use to take off the water pump pulley, the crank pulley and valve springs? We've already damaged the waterpump pulley by jamming something in the holes of the pulley to stop it from turning, now we have to look for a pulley! Lesson learned! lol
Thanks guys
Old 09-23-10, 02:44 PM
OneJay
OneJay's Avatar
Its easiest to take off the water pump pulley if the serpentine belt is on as it keeps the pulley from turning too much while you loosen the nuts. Also, try an impact wrench. The nuts shouldn't be all that tight though.
Old 09-23-10, 02:48 PM
ClearP
ClearP's Avatar
Ahhh too late for that lol, PS pump, tensioner and all that are off, I guess impact wrench is my next best bet, but it IS really tight tho
Old 09-23-10, 02:57 PM
2turbo1sup
2turbo1sup's Avatar
crank pulley = use the starter method and a crank pulley tool rented from kragen / autozone
x100 on getting an impact gun. Turn my 4 hour suspension job into 1 hour. I bought a craftsman impact and air wrench set at sears for $45 bucks,
Old 09-23-10, 03:08 PM
ClearP
ClearP's Avatar
alright Ill try the impact gun method!
Old 09-23-10, 04:14 PM
ViP_SC300
ViP_SC300's Avatar
PMed ClearP
Old 09-23-10, 04:39 PM
1siksc
1siksc's Avatar
Impact ftw
Old 09-23-10, 05:52 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I second that method too. If you cant get the crank bolt loose, then do this
1. slide socket onto bolt, then rachet into socket.
2. place long cheater bar over the ratchet
3. place the cheater bar under the car frame somewhere, where it wont turn
4. BUMP the starter.
5. Bolt loose
6. Drink a beer
7. Drink another beer
Old 09-23-10, 06:11 PM
ClearP
ClearP's Avatar
i guess i forgot to mention, the engine is on a stand with torque converter off... so if I crank the crank pulley, it just turns. Same with water pump pulley, if i use the impact gun, it just spins...
Old 09-23-10, 06:59 PM
Sup2jzgte
Sup2jzgte's Avatar
You need to hold the pulley with a belt or tool.............I kid you not I used and impact gun and an old dress belt to hold the pulley.
Put the pump in a bench vise
wrap the belt around the pulley and hold it tight and you the impact gun
Old 09-23-10, 07:10 PM
Nova
Nova's Avatar
impact, impact, impact. took 800+lb ft of tq to remove my crank pulley and i had to try 2 impact guns.
Old 09-23-10, 07:44 PM
ClearP
ClearP's Avatar
Hummm, belt idea is awesome! I'm gonna give it a try!
Old 09-23-10, 08:24 PM
Nova
Nova's Avatar
if your still having issues with the clutch fan- waterpump pulley bolts try using 2 wrenchs for added leverage (with the belt on)
Old 09-24-10, 12:15 AM
Exthultu
Exthultu's Avatar
An impact gun! Can't do half the jobs without it!
Old 09-24-10, 03:56 AM
Sup2jzgte
Sup2jzgte's Avatar
Actually I rebuilt countless cars from the ground up without Impact guns and only used hand tools .
Quick Reply: Toyota specialty tools
