PROS vs CONS of going turbo
Hey guys
I have a 93 sc400 with about 145 000 kilometres---I think that is about 90 000 miles-----and I was wondering what are the pros and cons of boosting with a turbo.
Obviously the car would be much faster and more fun to drive----but what are some of the drawbacks
--does it affect the lifespan of your engine---if so how much
--can it cause major engine problems
--can you turbo an engine as old as mine
--is the power you get from it worth the price
--can the 1uz be properly fitted with a good turbo-----I only hear about sc300's being boosted
--what --if anything----do you need to do to your engine or car before boosting with a turbo-----can you just bolt it on and get going---or is there proper maintenance or part swapps that need to be done first.
--can the auto tranny of the sc400 handle a boost
--the drivetrain same thing
Thanks in advance guys
Hey guys
yes-- depends on how thought out it is.
see above
sure.
that is a matter of opinion (but yes)
just about any engine can be turbo'd
proper maintenance, but you can't "just" slap a turbo on, there is other stuff that needs doing.
depends (supposed to be good for 400hp, i think)
meh. you will want to upgrade stuff, but it will handle more than stock.
see above
sure.
I did look at some of the other threads but they couldnt specificlaly answer some of the questions I had.
Like is it wise to turbo an older engine----and what sort of upgrades would I need to do before adding a turbo.
Also I cant seem to find a str8 answer on how much it would cost to put on a decent turbo----some threads have people saying a thousand dollars...others are saying up to $5000?
Anyways ill be in here and searching and im sure between the two I will find the info I need.
Thanks again guys
Everyone says it is easier and cheaper.
I dont know why it is so difficult to boost the v8.
My guess is there isnt much room for one?
Or does that fact that the v6's are straight inline engines as opposed to v style of the v8's make a dif?
Im gonna look into it.
Thanks
http://www.amazon.com/Maximum-Boost-...5308908&sr=8-1
I can not recommend that book enough. You will learn SO much about how and why a turbo system makes power. It should be required reading for anybody new to boosting engines, and is a great resource for even salty gear heads. I actually have a copy 2 feet from my right now under my nightstand haha.
