What did I do wrong here??
I bought a nardi 330mm wheel and an nrg short hub and they are not compatible even though I know people who use this setup!! What did I do wrong here? Does anybody know??
The bolt pattern is slightly off like if you were trying to put a 5x100 or 5x120 wheel on a 5x114.3...
Who else is using this set-up?
Upon further investigation I need the quick release which bolts up to the short hub. The short hub has a six bolt pattern that does fit some wheels but excluding nardi. The quick release (bolts up to the short hub) has a 12 bolt pattern that fits all wheels..
Basically you NEED a quick release if your going to use a nardi wheel lol I should probably do my research as opposed to word of mouth
1NewLexIS300
05-03-08 01:52 PM
