Is it a bad idea to disengage Over Drive while driving?
I have the habit, on the highway, of disengaging OD to pass or when I just want the burst of speed.
Is this a bad idea for the tranny?
It's perfectly fine for it, and I do it all the time. Actually, it's better for it to do it that way than just punching it, as you'll have the transmission shift, THEN you hit the gas, so you're not hitting gas DURING the shift. So go ahead, d-click overdrive and then blast on!
Jeff
Jeff
Leave the PWR button on PWR ALWAYS. You get better performance, quicker shifts, making your transmission generate less heat, less heat means it lasts longer, AND firmer line pressure, resulting in better gas mileage. Toyota ONLY put the "normal" mode on the transmissions for people who couldn't give two ****s about their car and complain when it shifts too firmly. ALWAYS ALWAYS use PWR mode.
For _anyone_ on this forum, who is here because they like their car, use PWR mode _always_.
Jeff
Jeff
Jeff
Jeff
Jeff
Jeff
ECT stands for electronically controlled transmission... meaning that the ecu changes the shift points allowing the transmission to shift at a higher rpm. If anything it will make your gas mileage worse, by a bit nothing really noticeable. Honestly the ECT button is there for the wannabe racers to feel like they have a fast car when in reality the stock SC is a boat.........its mostly a placebo more than anything else..........it is not going to change your 0-60 time one bit....it makes you THINK you are going faster and thats about it
turn overdrive on and off whenever you please, its made for it ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Always keeps the pwr button on cause it will make your car a rocket ship!!!!...seriously it has no effect except allowing the electronics to make the tranny shift at a little higher rpm...like others have said its a bunch of bs pretty much
edit: i have 235k on my camry and i never drive in "power mode"
