sc300 with a lexus 5.0l is-f motor
#35
In order for the piston angle sensor to clear the valve trunks, they have replacement helical axillary arm (20/1) and adjust it about a third counter clockwise from the conjoining tab
edit: my soarer v12 swap progress so far:
It fits with the stock auto but you need to modify the firewall and shock towers to shoehorn it in
#36
You have to re-taper the torque thrust valve to do it:
#42
what would be hella sick is if you can squeeze in a signal generator so you can adjust the air/oil mixture to a ratio of 1/45. Doing too much would lead to charge loss and you will seriously blow up the counterweights
#45
Sorry guys, you all have some great ideas but I just installed some jetpacks on my SC and it flies through SoCal traffic with ease. It's also solar powered so I don't need to worry about MPG.
