coolant leak!!Please Help?
I noticed two little drips of coolant hit the floor under my car. I checked the tank and it was low. You could still see fluid in there but it wasnt full like it should be. I filled it up and turned on the car and it started dripping out again, a lot this time, but not enough where I couldnt see coolant in the tank. I took off the skidplate and the leaks seem to be coming from underneath the fan where the ac lines and stuff are. I couldnt exactly identify the leaks though. Im taking it to a mechanic tommorow but dont want to get ripped off. Anyone know what I should do or is this a common problem. The car is a 92sc400 with 125k on it. Ive been driving the car all day and the temp gauge is fine and has stayed fine even when the coolant was leaking out. Thanks
nikovdh
05-04-18 04:34 PM
