CCFL Halo LED Projector Headlight
First off "that company" is banned because they don't pay to be a sponsor here so club lexus doesn't want their name to be promoted. TSX projectors from an Acura TSX fit very well in our headlights with a simple bracket. If you're new the retrofitting there's a lot of research ahead for you, but it's worth it. The overall job is fairly simple once you understand what you're doing.
SCNV
which would be better, swapping the clear lens from the eBay light, or delining my stock headlights??
remember we dont drive a Honda..
I distinctly remember there being a thread where the #1 complaint was no beam-angle adjustment, meaning you cannot control where the light shines, in the trees, vs. 1' in front of your car.
now correct me if Im like said "old timer", but headlights that you cannot adjust the beam position are cheap.
You want up to date, ADJUSTABLE headlights, that look good? Take Klaus's advice and do it right.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
p.s. the CCFL's which stand for "cold cathode fluorescent lamp", isnt really a ccfl. all it is, is 2 plastic rings with light bulbs behind them.
1) Replace the OEM projectors with a high end HID projector retrofit, such as the TSX, Audi or BMW lenses
2) High end ballasts such as Denso or Phillips
3) Phillips D2S bulbs
4) Clear lens swap from the ebay headlights.
Only way to go...
For those of you that have not seen them, Mine:
![](http://i106.photobucket.com/albums/m242/SC400TT/Complete1.jpg)
![](http://i106.photobucket.com/albums/m242/SC400TT/Complete4.jpg)
Some of you won't like the LED Daytime running lights, but I do, that is why I added them.
Ryan
Custom cut from an RX 300 OEM reflector. I used 1 for each side...
SEM, high gloss with separate Clear and UV protectant. I may open them back up later and match with the PPG Global I painted the car with. But looks so good as it is, I may have no need to change it out.
Ryan
Ryan
Here is the a pic of the ebay lights on my car. They okay for the price and they look pretty good I do get the odd head turning. So all in all they are not bad for what they are. Would be cool to something like SC400TT, those look really good but I don't have the experience on separating the lens from the housing. Here is the pic anyway.
![](http://carphotos.cardomain.com/ride_images/4/568/1889/38918444016_large.jpg)
s4play
10-27-11 07:12 PM
